Steel plate connection for Cross-Shape and Cruciform Flanged section columns
nelsonhp3
nelsonhp3
Dears,
I need to place base connections on structural columns in a Flanged Cruciform format, but I haven't been successful.
This scenario is fairly obvious because there isn't a Section Shape for it in Structural Section Properties.
However, I also tried using a Cross-Shape family and was unsuccessful, despite this type of section being available in the software.
Am I doing something wrong?
Is there a workaround?
Some screenshots for a better context:
(Ignore the "Material for Model Beravior: Other". I've already changed to "Steel")
jay_colc
I would suggest the Section Shape it is outside the Scope of Automated Connections as per the link below;
Help | Supported Structural Steel Shapes and Families for Steel Fabrication | Autodesk
Jay Colcombe
Autodesk Certified Instructor
mari.shimode
Hi @nelsonhp3, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future.
If you still have the issue, please let us know. Thank you.
Mari Shimode
