when modeling a custom sections portal frame from welded plates for columns and beams, do you people create in-place steel connections between columns and rafters or import the structure to another software to do it?
which version of revit do you use?
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
If the columns and beams are certified, according to the specifications here: http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-6244E741-5D14-4DAD-AE25-5069F71B69F3 , you should be able to place steel connections starting with Revit 2017. Please find the instructions for placing standard connections list here: http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-24C33598-E6B7-426A-ABBD-F0BDFA2EACC1
Best regards
thanks for your answer. but I am talking about non certified families. built up sections for rafter and cols. how do you do connections for? do you model them in place individually or use another software? how do you usually do it ?
