Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Steel connections - Beams
2 REPLIES 2
mairh_tsek
433 Views, 2 Replies
Hello all,
I want to create the 2 connections (green color, as in the other side of beams), but I don't want the horizontal beam to be cut. Is there any way to rotate maybe the connection and put it in the correct place (the connection is created automatically in the position of red circle) , or not sure how could I do this..
Thank you in advance!
2 REPLIES 2
Rob_Merriman
in reply to: mairh_tsek
Hi @mairh_tsek
When you apply a connection there is a main member and a secondary member, lloking at you screenshot these are the opposite way round.
If you singe click on the connection you will see a big solid blue circle, this is the main member, you will also see a blue circle with a 2, this is the secondary member (See screenshot below)
You can click and drag on either of these to swap the main secondary member, or simply click the small blue circle under the 2 and this will swap them
This should give you what you want, if not could you please upload the Revit file
Rob Merriman, AEC Technical Lead, Graitec
mairh_tsek
@Rob_Merriman ,
It works, thank you for the explanation!
