Standard shaped rebar doesn't fit cross section
aleksei.tkachenko
aleksei.tkachenko
Hello
I am starting to work with reinforcement in Revit and having an issue right from the beginning. What I am trying to create is rebar shape 15 for simple cross-section. Every time I do it, I have wrong form no matter how often I push "back space". That is why I have two questions: is it possible to change the angle for rebar with standard shape by editing its parameters. If not, then how can I adjust angle to my form. Thanks in advanced.
aleksei.tkachenko
Attaching file with cross section
CristinaJianu
Hi Aleksei,
Did you try to sketch the rebar?
Cristina
aleksei.tkachenko
Hello
Yes, I have tried it but when I edit sketch, Revit creates new shape for reinforcement bar. I think it should be possible to change angle between rebar segments without changing its shape.
