SPOT SLOPE TRIANGLE
SPOT SLOPE TRIANGLE
DParkRMAK
SPOT SLOPE TRIANGLE
DParkRMAK
I have been trying to use the spot slope with the triangle option but I am unable to select triangle from the dropdown. It defaults to arrow but is greyed out and I can't change it. I made sure my units were set to rise/12". I can't recall ever having a problem with this before. I tried it out in Revit 2014 and 15 and same thing. I am not sure what I am supposed to do. it always just worked fine.
ennujozlagam
hi, try to pick "arrow head slope" go to properties > edit type > and change leader arrowhead or go to manage > additional settings > arrowheads > change arrow style. hope it helps. thanks
DParkRMAK
Sorry but I dont follow. I don't see anything that says arrow head slope. It used to be that you just selected the type as triangle or something if I recall. It was just a simple selection to change it. I dont seem to have anything but spot slopes with slope as a type.
Can triangle spot slopes be placed in plan view? If not, why not?
I tried placing one in a section view but found I could not place either type of spot slope on this object. I guess it does not work on a model in place foundation? This is a banked ramp that I modelled as a swept blend.
ennujozlagam
hi, please see attached. thanks
or you check it here how to place slope in model in place slope.
http://revitoped.blogspot.sg/2013/05/tag-slope-of-ramp.html
DParkRMAK
Thanks but I am not talking about the leader arrowhead. I am referring to the actual spot slope triangle option that I guess is not available in plan. What I am labeling is an actual wedge and the triangle slope is more representative but it just isn't available in plan. Thanks for the link to the model in place thing.
mmcintosh-ral
Thanks for mentioning that you were in a plan view on this. I was having the same problem today.
Just saving some linework for reuse in one location that happens to be a plan view, but part of the linework is angled slopes for roof crickets. Couldn't figure out why I couldn't get the slope to work until I read your note.
Thanks for the tip!
