Snapping of nut center on steel connection(structure connection) not working?
TiStars
Advisor Advisor
TiStars
I am using steel connection (or Structure connection whatever you call it) in Revit 2020.2.9 to connect a column to foundation.
I need to show the distance between the bolts/nuts as below shows, but snapping seems not working on them.
The edge of the plate reacts to the snapping of "Aligned Dimension" command like below, but the nuts don't.
Appreciate to any advice, thank you.
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
Ahmed_Muharram
I tried so many times, it is not easy the point of the middle of the anchor is existing but you have to pick by a lot if effort using Tab Key and the view range to be showing the anchor without covering it.
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
TiStars
Many thanks @Ahmed_Muharram !!!
Yes with your confirmation, I managed to find the center of the anchors like below!
I am finding the anchors don't react to "Aligned Dimension" command until you zoom out a bit like below shows.
  1. I set scale to 1:2
  2. Click "Aligned Dimension"
  3. zoom out till it is such small, and hover over mouse near them (not top of them), then the center of anchor will react and highlight.    (Repeat the red part until the center of anchor reacts)
  4.  Click to set the first point of dimension.
  5. without changing scale nor zooming,  hover over mouse near the other nuts and click if the center of anchor reacts to finish dimension.
Key point:
Keep trying zoom in and out and hover over mouse near the anchors
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
larisa_bray
Community Visitor
Community Visitor
That is all BS. All Connectors should have reference lines to dimension to
AntDrt
Hello @TiStars
Set visual style  to wireframe and get the center of the hole.
Much easier.
Antoine
AMG Fechoz
Serrurerie & Equipement Scénographique
www.amg-fechoz.com
larisa_bray
Community Visitor
Community Visitor
Nope, does not work! I tried all means. Moreover you can not align bolts if I broke the connection and used only bolts
MJMoore678KE
Any update on this? This is very frustrating.
