SMART Graphic scale "married" to a Views Set Scale
simmonsEDP9W
Message 1 of 8
simmonsEDP9W
Is there a way to have a SMART Graphic Scale in Revit?  Whereby, it is married to the views scale?
So that, if you change the scale of the view, the graphic scale will also adjust?
Any insight on this would be appreciated.
David
Replies (7)
Message 2 of 8
simmonsEDP9W
i can place a dumb graphic scale on a plan view. however, there is a potential for error. if you change the scale of the view - a dumb graphical scale will not update. Therefore, continuous baby-sitting of the graphical scale is necessary.
A smart Graphical scale needs to be married to the views scale setting.  doable???
Message 3 of 8
simmonsEDP9W
please help 🙂
Message 4 of 8
simmonsEDP9W
No answers?
i was thinking of incorporating it inside the "View Title" family.  The "View Title" family has a label that already has a parameter reading the "View Scale".  Is there a way to add a Graphic Scale inside the "View Title" family that will read the "View Scale"???
Message 5 of 8
simmonsEDP9W
No thoughts............??
Message 6 of 8
apjones
This topic has been discussed before. The way Revit handles view scales (viewports) and annotative objects makes this difficult, if not impossible with the current abilities, at least as far as I can tell.
If someone has figured it out, I would guess they would post a solution.
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
Message 7 of 8
You can create a graphics scale detail (not generic annotation) family, drawn correctly to size, and place it in the view.  You may need more than one family if your views varies from very small to very large scales.
I just included graphic scales of common scales on the border of my titleblock family and called it a day.
Message 8 of 8
simmonsEDP9W
ToanDN - "I just included graphic scales of common scales on the border of my titleblock family and called it a day".
yes, i've thought about this. i'd just have to convince a few dozen clients to allow it to live in their border. Some clients get very picky with their border.
Thanks!!
David
