The issue here is the Pad Foundations do not give snapping points to the Edge Faces as the Beam and Structural Foundation are a different Category.
Placing additional references to snap to in elevation and setting a Work Plane (Grid A) you can draw using additional Grids/Levels/Reference Planes and Snap accordingly and extend the node to remove gaps
This would be a Lengthy process the only other alternative I could think of at this time would be to use a Structural Foundation Slab with correct Depth and Thickness and add a Slope Arrow and this would clean up automatically and could be copied around as required and edit the boundary and slope as required?
Jay Colcombe
Autodesk Certified Instructor
