I am using Revit LT 2024.2 on Windows 10. I'd like to just show the bottom line of a slab edge on my plan view and not the line where it intersects with the slab.
I have seen this information and added this option to my revit.ini file but it did not work. Discipline is set to structural. I tried using linework tool as a work around to set only the solid, intersecting line as invisible and it hides the dashed, bottom line of the slab edge as well as the solid intersecting line. (see 2nd picture).
Does the .ini file option not work with revit lite? Am I just outta luck on this?
