I have a calculation of concrete and wood consumation, can i occult or do something to show only the total calculation, on the image on red only the 29,85m3 and the 400,67m2
Solved by jay_colcombe. Go to Solution.
Make sure you set an appropriate sorting reference and then untick Itemize every instance
Also for some Categories and sorting Preferences you need to set the Formatting to "Calculate Totals" also to add them up in the Table
