Show element without increasing view depth
chrismunt
chrismunt
I understand that Revit works with view depths. And if I cut a true section through my building it will only show elements that pass through the section mark location. I also understand the reasoning behind this.
That said. Is it possible to show an element in full without increasing the view depth of my section?
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
L.Maas
A solution might be to make use of two views on top of each other like this
Then on a sheet
Louis
Please mention Revit version, especially when uploading Revit files.
chrismunt
Simple. Creative. Love it. Thanks.
I'll mark your answer as the accepted solution. If anyone else has idea's I would still like to hear them.
You can toggle Far Clip Settings between Clip and No Clip.  That doesn't affect the Clip Offset (or View Depth as you called it).
