Shortcut for multiple align?
stereomp34
stereomp34
Is it possible to set a shortcut for multiple align? Checking and unchecking multiple align box every time is inefficient.
I'd like to set normal align to AA and multiple align to AX, don't see it in shortcut settings, maybe there is a workaround or 3rd party tool that tackles this issue?
jay_colc
it is not possible the only editing you can do is to edit the Revit.ini file to choose whether it remeber the "Multiple" option from the last used.
Help | Remember Modify Tool Settings | Autodesk
There are addins which may cater for this - have a search from the link below for similar tools
Align | Revit | Autodesk App Store
Jay Colcombe
Autodesk Certified Instructor
handjonathan
Hi @stereomp34
Thanks a lot for posting your question to the forums!   Has the solution suggested by @jay_colc helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
