Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Shear connection cuts wrong beam
3 REPLIES 3
jim
419 Views, 3 Replies
After selecting both beams for the connection, the plate mounts on the wrong beam.  With Advance Steel you first select the main beam then the attaching beam. With revit you select both beams and connect with the context menu. I don't see any way to change selection of the main beam afterwards.
Jim
3 REPLIES 3
mihai.sandu
in reply to: jim
Hello Jim,
In order to change the main and secondary beams, you must select the connection and then use the dots to select the correct primary input.
You can find more information in the Steel Connection Help.
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-08835C01-DE99-4DB2-9197-1064300AC36E
Mihai Sandu
Sr. QA Analyst
yurikim
in reply to: jim
Thank you for your posting @jim
Also please take a look at this video:
http://autode.sk/2mKjbyc
Hope this helps.
Yuri Kim
Product Support Specialist, AEC
jim
in reply to: yurikim
Jim
