Shaft problem
Shaft problem
Shaft problem
Hi, i'm trying to make shaft opening but i obviosly miss something general .
Please share some info about creating shaft openings.
www.TechRoom.bg
The Shaft Opening default Base Constraint will now default its extents based on the level/view you initiated the command in.
If you’re now in a floor/ceiling plan view, click Shaft Opening command, the default Base Constraint will be current level.
If you’re now in a section/elevation view, click Shaft Opening command, select a plan view in Go To View dialog, click Open View, the default Base Constraint will be the selected level.
Here is official autodesk knowleadge info about shaft openings
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
