Setting priority of elements
 Hi everyone
I was wondering if I can set the priority of elements in Revit like columns, walls, beams and slab
If I draw a column and a wall at the same place, wall takes column's volume right?
If I draw a slab and a beam at the same place, slab takes beam's volume
but slab doesn't take column and wall's place. They just exist at the same place
So I know there is a priority between the elements
Is there any way I can reset the priority in revit?
No.  But you can always switch join order to choose which one gets the priority in cutting.
It was not the answer I was looking for but I had to know
basem170121
Community Visitor
Community Visitor
can you explain more
