Self-expanding concrete beam
KlaudiaDiana
KlaudiaDiana
I am required to do certain thing for work and I don't belive there is no faster or/and easier way to do it.
Our budget management requires to create structural beams with their additional suport length (+25 cm each end)
What I do is, I create the beam in the opening and then stretch it with blue dots to the required support's length.
the problem is, then I need to go to the analitical model and align the nodes back to the opening's width.
I am looking for solution that will let me extend the beam but the nodes will stay in the opening. It would be great help if I could just write the value of start and end extension.
PS. It is probably worth mentioning that the beams are concrete.
Ahmed_M_Heteba
  • Could you add screenshots to get the point you need
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
KlaudiaDiana
I need beams to look like this in the regular 3D view:
But I need analytical model to look like this:
Right now I do it in following way:
1) I draw a beam that is as big as the door opening
2)I change it's length to length of the opening + additional length at the supports
3) Then Analytical model looks like this:
4) then I need to change nodes back to the corners of the walls. I use align to do that.
Is there another way?
Ahmed_M_Heteba
i think this is the right approach you use
