Select level in 3d view
hanslammerts
hanslammerts
There is no option possible for selecting a level when you link or insert or link a CAD file in a 3D view.
Revit automaticly places it at the lowest level. Why not +0.000? Both, More logic.
diana.rivera.ruiz
Hi, when you link a CAd in 3d View, select the link, and you could select the option base level and offset level if you want.
hope help you,
Regards
Diana
hanslammerts
I know, but it would be preferrable if this button would work in the first place
chrisplyler
You would rather select the level from a drop-down list and then place the link, rather than place the link and then select the level from a drop-down list?
I understand. That would make the task much easier. You should submit an official feature request to Autodesk.
hanslammerts
Yes it would be a bug fix, not a new feature..
