@wz264 wrote:
- I'm sorry but your solution lumber.gardwin was not helpful or proper if I'm not mistaken. After searching for a solution in different forums none was found. After carefully reviewing one can find which view template is applied to the view by simply looking on Properties Panel, scrolling down to Identity Data
- View Template which will say None or whichever template name has been assigned and from there you can edit, duplicate or start a new one.
Hope this answer is clear and straight forward.
Hi @wz264 ,
It's okay. I believe you misunderstood the question "See which views have a certain view template".
Your answer is considered correct when you want to manually check in the properties palette which view template is assigned to a single View.
But @david.gardin is looking for an easier way to check which views have that particular view template was assigned to. If you have 100 views to check, it will be very difficult to check one by one manually, rather, just create a view schedule.
Hope it clarifies why david accepted our solutions.
Dar
