Section Cut Through Swept Blend Beam Not Displaying on Curve
mattweaver9MTQ5
mattweaver9MTQ5
I have a beam family that I created using a swept blend. It behaves how I want it to with the exception that when the beam is curved in plan, I am unable to cut a section through the curved section. If I cut a section on a straight segment it displays normally. Is there any way to fix this? See attached screen captures for further clarification. The first image shows a plan view, second shows the section through the straight segment, and the thirds shows what appears when I go to cut through the curved segment.Capture1.PNGCapture2.PNGCapture3.PNG
edit the family and untick "Show family pre-cut.."
mattweaver9MTQ5
I tried doing that and reloaded the family into my project and the family still displays incorrectly when cut through the curved segment.
can you share the family?
mattweaver9MTQ5
See attached, thanks in advance.
