Schedule, information per sheet
SEFLIL
SEFLIL
Hi!
I have multiple sheets with wall and floor elements reinforced with 2d-reinforcement familys. The shapes ofthe reinforcement is managed by parameters a, b, c... and so on. I have created a schedule for these parameters but it displayes the total in the project. What I want, is to put the schedule on each sheet, and only display the reinforcement that is visible on that sheet. Is there a way to manage that?
And one other thing, is there a way to put the schedule in a legend?
aleksei.tkachenko
Hello
You need to check "Itemize every instance" in order to show all rebars in the schedule. As for schedule per sheet, you can use partition parameter. Create unique name for each partition and then apply filter to show only rebars from one particular partition in a schedule.image.png
It's impossible to put the schedule in a legend. But you can put one schedule on multiple sheets.
SEFLIL
Partition parameters? I dont find any information about it?
@SEFLIL wrote:
Hi!
You cannot have the wall schedule to filter per Sheet automatically.  Do this:
- edit the wall schedule and add a new text parameter named Sheet
- go to each view on each sheet, select the walls in that View and enter the sheet number in the Sheet field of the walls in properties
- go back to the schedule and create filter per Sheet value, duplicate the schedule and change the filter for each sheet
* it will get complicated when you have walls appear in more than one sheets
* it's an unusual workflow and you will have to manually update the sheet information of the walls should you move a view from one sheet to another, or move a wall to a location that make it appear in a different sheet
* no you cannot include a schedule in a legend
aleksei.tkachenko
Hello
As far as I understand @SEFLIL asking about scheduling of reinforcements inside walls and slabs and using Partition parameter is the most common way to sort rebars inside one project.Skjermbilde.PNG
