Announcements
Rotating Structural Components
sam.stibbs
sam.stibbs
I have a bridge that I have modelled but horizontal but now I need to rotate it by 5 degrees on an incline.
I try and do this through the rotation method but it says 'Can't rotate element into this position', what is the correct way of doing this easily?
Sam
Ahmed_Muharram
could you add the file to see whats happening and try to solve it
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
sam.stibbs
Sure here is the Revit file I am working on
Ahmed_Muharram
Hi
i have tried to rotate it but the message came up with problem in dim and reference planes
i have deleted the dim and reference planes then i rotated it in 3d as you see in the attached file.
if it helped mark as solutin
BIM Manager
sam.stibbs
Sorry maybe I wasn't clear enough, I was trying to rotate the bridge so that it had an incline of say 4 degrees. Not rotating it the way you have done in the file you attached.
