Rotating grid head
Rotating grid head
Mohammed_Ata
Rotating grid head
Mohammed_Ata
Dear, All
While working on a model and has a large area in plane. I rotated it 90 colockwise.
The grid head is also rotated. I am skiing about is there a technique to make it horizontal do can be read easily ?
Please have a look.on this scteen shot.
MostafaElashmawy
instead of rotating the view in sheet, in the view itself, select the crop of the view and rotate it using the ordinary rotate tool.
Mostafa Elashmawy
MostafaElashmawy
for more clarification, follow below screencast.
Mostafa Elashmawy
aleksei.tkachenko
Hello
If the approach described by @eng.mostafa2414 doesn't work for you by any reason, try to use following method that actually rotates grid heads.
aleksei.tkachenko
Here is a link in case if embedded video doesn't work properly.
https://knowledge.autodesk.com/community/screencast/19bfcb7a-d588-4f75-99bb-c5842a5ff0ed
Mohammed_Ata
Thank you so much for your all interest.
UP860073
This won't work if you have to use a mixture of sheets (rotated and not rotated). Is there a workaround?
