Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
ROTATE DETAIL ITEM TAG ACCORDING TO DETAIL ITEM VERT.-HORIZ. LOCATION
3 REPLIES 3
simmonsEDP9W
585 Views, 3 Replies
I' m trying to make a detail item TAG rotate automatically (Horiz. or Vertical) depending on which way the detail item is rotated in plan view. (Horiz. or Vertical).  i do not want to click on the tags [Horizontal or vertical] placement every time i tag something. i want the tag to rotate automatically depending on the orientation of the detail item.  anyone currently have this implemented??  please help. thanks. david
3 REPLIES 3
EdwinG
in reply to: simmonsEDP9W
set this in the tag family
simmonsEDP9W
Thanks, i knew it was in there....just missed it.
simmonsEDP9W
in reply to: EdwinG
This worked in R2022.
however, this checkbox doesn't seem to perform the desired rotation in R2020-R2021.
anyone know this problem???
thanks, David
Forma Design Contest
