Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Road Bridge Alignment on Revit
2 REPLIES 2
nadifa.aulia98
1004 Views, 2 Replies
nadifa.aulia98
Hello, I'm new Revit user. I watched a video about bridge design workflow using autodesk product. In this video I found that we can make alignment on Revit(https://customersuccess.autodesk.com/challenges/bridge-design) ,  I usually made it using Civil3D.   I want to know how to create that? would you mind to give me the big idea?
2 REPLIES 2
andre.micka
I think the workflow is c3d to infraworks and bridge link from infraworks to revit
in reply to: nadifa.aulia98
With the Sofistik plugin Bridge Modeller, there is the same option called bridge axis.
Or if you can use Dynamo, it's possible to have something like this.
