Hello
When I export drawings from revit to dwg. Viewports in dwg file are showing wrong location so that drawing are missing in layout.
Problem seems to be only with these drawings that contain rotated revit views .
I mean that if I have detail that is in angle. First I make assembly and assembly views. I rotate the view so that it would be in parallel or in angle that i want in sheets. Now I exporded these detail drawings to dwg and drawings that contain rotated views are showing wrong place in modelspace.
Strange is also that before opening file, autocad file preview shows all in right place.
Added Dwg(-error with viewpots in layout) and PDF(-how it looks in revit )
Is there fix or solution for that problem.
I have many drawings with this problem.
I have revit 2015 Update 4
1. I tryed to export in different computers ....still same problems
2. I made revit audit ...still same.
3. I made new file ...same problem seems to be.
4..... what to do ?
Kaupo
Hi Mr Tennokese,
This issue is a known issue and it is been already escalated to the development team and they are working on a fix but I don't have any time line when this could be fixed.
It is an issue with the coordinate conversion for different viewports with special view coordinate system.
I will keep you posted in case I have any updates
Не нашли то, что искали? Задайте вопросы в сообществе или поделитесь своими знаниями.
