Revit Template - New Structural Plans Set to STRUCTURAL
simmonsEDP9W
simmonsEDP9W
  • Revit Structural Template
When Creating New Structural Plans: via drop down View<Plan Views<Structural Plan
ALL new structural plans is currently set to a Discipline of: Coordination.
i want ALL New Structural Plans SET to a Discipline of: Structural.
That way, when creating new Structural Plans they will Automatically have a Discipline of Structural.
David
hmunsell
What version of Revit are you using?
Which template are you using?
When making a new view, under the Type drop down is it set to Structural Plan?
  • select Edit Type and check the View Template being applied to the Type.
  • make sure the View Template is set to Structural.
Howard Munsell
simmonsEDP9W
Revit 2020-2023
roger that!
Thanks!
EdwinG
You can also set this
simmonsEDP9W
ASDF.jpg  Box "Greyed" out.  solution?
EdwinG
Button above must contain a View Template
