Revit Structure 2017 beam to column connections missing
Watching a youtube video for beam connections in revit 2017. It says these are already installed in 2017. I click on the connections tab and all i get is Generic connection and no window for the connection type. I went to families and inserted a few clip angles. What am i missing?
A_MAQ
Hi @Anonymous,
you need to install the add-ins first, then you can go to connection tab to choose the connection type
below is the link shows you more
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revit-Model/files/GUID-B2CBA19E-3CA8-422F-AB7F-E04EDAEC556E-htm.html
Best Regards,
Autodesk Expert Elite
