Revit Space Frame
Revit Space Frame
shefypattambi
Message 1 of 11
Revit Space Frame
shefypattambi
Hii,
I need a small help. I have a large sloped roof area built by Space Frame as shown in the pic. The space frame is 3x3m center  to center. unfortunately the center point of diagonal members is not coming exactly at 1.5m. How can I  achieve the center point at exact center of the space frame bay.
Replies (10)
Message 2 of 11
Alfredo_Medina
The center point (the dot) looks to be in the center of each square. Please provide more images to illustrate in a better way the issue and what you are trying to do.
Message 3 of 11
shefypattambi
There is a small difference in the center point. I don't know the exact reason. So I change my Space frame curtain panel based family to adaptive component family  as 3 Parts -  (Top Chord, Diagonal Chord and Bottom Chord). Kindly see the pic. Now I could achieve what i need for the first portion of the roof that belongs to the first expansion joint. when I model the adaptive component at the second portion of the roof it is not repeating as I need. Any suggestion ?
Message 4 of 11
Alfredo_Medina
About the first issue, the distances not being equal, that doesn´t seem difficult to fix. You would need to make the total distance a multiple of the spacing, and relate that to an integer parameter that control the number of divisions.
About the second issue, the diagonal members going to the wrong place, it is difficult to say what´s going on without seeing the file. Can you post the family?
Message 5 of 11
shefypattambi
Thank you for the tip Mr. Alfredo. The second issue was due to my bad modeling ideaSmiley Sad The reference planes that i draw for dividing the surface was not intersecting each other . Once I corrected it is working fine.Smiley Happy
Message 6 of 11
I have similar problem, I created a space frame unit file for a form I created, but when I change the divided surface pattern to the space frame, I get this unable to create curtain based panel error from revit, I created a small less complex form and it worked, can't still figure out what's wrong
Message 7 of 11
shefypattambi
Hi @Anonymous,
Could you please post a picture of your failed Surface ?
Message 8 of 11
Shefylattambi OK, how do I upload pictures here
Message 9 of 11
shefypattambi
Hi @Anonymous,
You can insert pic by using any of one the method shown in the pic.
Message 10 of 11
Message 11 of 11
this is how the form looks like, I want to use a space frame for the structural details
