Revit precast slab
Revit precast slab
info
Revit precast slab
info
i've found this image on Revit site, about precast element (predalles slab).
How cain I insert this type of slab?
teodorb
Hi @info,
In order to achieve this you need to install from Desktop App the Structural Precast Extension for Revit 2019.
More details can be found here:
http://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-3AA696FA-8CE6-43CC-AB60-D0BC305351EC
Kind regards,
Bogdan Teodorescu
Product Owner
info
Hi teodorb,
I have already installed precat module, but did not find precast slab type showed in attached image (predalles slab).
Kind regards,
info
teodorb
Hi @info,
In order to obtain this kind of slab you ned to do the following:
- Create a structural floor;
- use the split command and select Girder Slab
- On the obtained assemblies you can use the reinforcement command
Let me know if you need additional information.
Kind regards,
Bogdan Teodorescu
Product Owner
