Where can I find "Content Generator" for Revit 2017?
Revit 2017
Revit 2016
Solved by Rafal.Gaweda. Go to Solution.
Hi Priit
Not available anymore starting from v.2017
If you need sections generated by Content Generator - generate them in 2016 and upgrade generated rfa files to 2017 version
RFA file you saved from revit revit 2016 for inclusion in the 2017?
This is the main reason I have not using Revit 2017 yet. I am a constant user of "Content generator" and "Freeze drawings".
Is there some reason behind that decision?
How can I make drafting view copies now from the model?
Autodesk,
Put me down also as a user of Content Generator and Freeze Drawings that wishes they were available in 2017.
If Autodesk has removed these features, can someone here recommend other programs to accomplish the same tasks?
thanks for any help in this,
Dan
Charl van der Merwe added this to Revit Ideas if you would like to vote for it:
