Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revit - Create Curved Bridge using Model in-place
1 REPLY 1
priadi.lesmana
1077 Views, 1 Reply
Hi everyone,
I'm trying to create in place model for a curved bridge/overpass using swept blend with the help of Civil 3D for the centerline path. And i've encountered some problems regarding the reference planes used for profile 1 and 2 in the swept blend when modeling at the spiral alignment from Civil 3D.
Can we rotate the reference plane in the swept blend so it can match the section intended? If not, how do we solve it?
1 REPLY 1
Avaris.
in reply to: priadi.lesmana
Your profile will always be perpendicular to the path of the sweep, it means the start of your path is not perpendicular. One option is to correct your path zo it starts absolutely perpendicular. Another option is to extend your path and trim the end of it with a void solid. Not particularly nice, but it works.
State of Sustainability Webinar
