Revit crashes when duplicating view
I've lost two solid work days to non-stop crashing, and I've narrowed down the issue to duplicating views. Every time I try to save after duplicating a view (not "with detailing" or "as dependent"), the program freezes and no amount of waiting thaws it back out.
I can't use a dependent view because I need different cut planes. The only way I can find to create a new floor plan is to go to View -> Plan Views -> Floor Plan, but then I can only use a level that's already been used if I uncheck "Do not duplicate existing views" which goes right back to the original problem.
Is there a reason two floor plans can't be created from the same level? Is there a way around that? Or do I just have to create a new level at the same/similar elevation?
Thanks in advance
