Revit column tag borders
osamaelazaizi
osamaelazaizi
How can i control the borders of tags with dimensions?
also how can i draw a rectangle for example and constrain it with tag borders?
dferreira-blackwell
osamaelazaizi
thanks sir for your resonce
but that is not what i mean
i mean that label borders can be controlled with dimensions like any shape all around tag
in order to modify any shape i will draw all around the tag , but label borders & the shape i will draw will be constrained&connected with each other
Do you want the tag to auto fit the label content? Edit the label type and turn on Show Border.
osamaelazaizi
thanks sir, but i don't mean it
i mean when i drew a border (circle - rectangle - ....) and put the tag label in it, if i got a lot of words in tag the tag border i drew will be smaller than tag label words, so i want the tag border i drew will be constrained with label border
