Revit Certification - Results
ArmanMargaryan
ArmanMargaryan
Will my Autodesk account receive the Certiport exam certificate?
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
Jamhmer_Oc
Hi @ArmanMargaryan
An invitation to accept your badge will be sent to the same email address you used to register with Certiport. Sometimes it takes a few hours to arrive.
To view your certificate, you can access certiport and in the tab My transcript you will see your certificates and next to it will be PDF.
Search for your name here. https://www.certiport.com/Portal/pages/ACPSearch.aspx
Jamhmer Oc
ArmanMargaryan
Thank you for answering.
I mean the badge in the picture․
Arman Margaryan
Linkedin | Facebook
Jamhmer_Oc
@ArmanMargaryan
Log in to your credly account and check who issues the badge. If you issue Certiport, it will not appear on your Autodesk Community profile, if you issue Autodesk, it will appear on your profile.
Jamhmer Oc
ennujozlagam
https://certiport.pearsonvue.com/Certifications/Autodesk/Certifications/Badging
janake37117GMP8Q
Community Visitor
Community Visitor
1 good day can somebody tell me if revit exams for certification are on line  or face to face
2 i would like to know the step by step for these
Autodesk Certified Professional in Revit for Electrical Design
i´m in Colombia and here there are not ATC
thank you
L.Maas
The exam is done supervised by an Autodesk certified company. You might try one of the Autodesk resellers in Colombia. I expect one or more will offer those services.
Louis
Please mention Revit version, especially when uploading Revit files.
