Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Revit 2024 bug - voids un-cut themselves when you move something
4 REPLIES 4
ron
332 Views, 4 Replies
ron
My first project using Revit 2024 & I notice when I move an object (such as a wall panel), any voids that were previously cut inside that wall automatically UN-cut themselves.  Even if i was just moving the wall left or right a tiny fraction & the void is tied to a ref plane not the wall itself.
After moving, you then have to go back and cut all of the voids again.
This never happened in the older versions of Revit.
Also, all dimensions get deleted when you move an object, where older versions of revit would keep the dim & automatically adjust the # to the new distance without deleting it.
Does anyone know why Autodesk would add this horrible change to 2024?  I assume it's a bug?
Tags (1)
4 REPLIES 4
jay_colcombe
in reply to: ron
jay_colcombe
Probably the first thing i would suggest is you ensure you have all Revit 2024 updates installed so it not a bug that's been resolved!
But you possibly have Disjoin box ticked when moving elements which will force it to loose its association to Dimensions and Voids?
Jay Colcombe
Autodesk Certified Instructor
Jay Colcombe
in reply to: ron
Unchecked Disjoin box from the option bar below the ribbon when move elements.
ron
in reply to: jay_colcombe
ron
yes, that fixed it.  thanks.  not sure why that box would be checked as default.
ron
in reply to: ToanDN
ron
yes, thank you!
yes, thank you!
