The tip here is once you have placed the reinforcement you remove the Area System
You would use the layout method of maximum spacing of 100mm to get as close to the 100mm as possible and it will automatically calculate the number of bars required.
Remove the System
You then need to change this to Number with Spacing and edit the number (usually reducing the number by 1) so it fits within the host.
Jay Colcombe
Autodesk Certified Instructor
