(Revit 2023) Structual area reinforcement fix Layout rule
I_stegenga
I_stegenga
Im working with the Area Reinforcement family but i need exacly 100 mm spacing. Is this possible? it isn't possible with maximum spacing and fixed numbers to get exactly 100 mm spacing.
Does anyone has a easy solution for this?
Hopefully you guys can help me!
Thanks!
jay_colcombe
The tip here is once you have placed the reinforcement you remove the Area System
You would use the layout method of maximum spacing of 100mm to get as close to the 100mm as possible and it will automatically calculate the number of bars required.
Remove the System
You then need to change this to Number with Spacing and edit the number  (usually reducing the number by 1) so it fits within the host.
Jay Colcombe
Autodesk Certified Instructor
