in general I like the idea that the analytical and physical element has its own properties (material, section,...). It is also good that they are not linked to each other (coordinate wise). But the creation of the analytical model based on the physical elements is a pain in Revit 2023 and a huge step backwards in my opinion.
The automatic generation of the analytical model (now via the Dynamo script) is way worse compared to the old automatic generation. No proper connection of the walls, bad connection between walls and slabs, ... . Not a single structure where I was able to use it and the result was good.
I would like to show that on a very simple example: 4 walls + 1 slab on top.
The following picture shows the expected result in Revit 2022:
If you run the automatic conversion in Revit 2023 it looks like that:
I played with priorities and tolerances but without success.
The automatic conversion even fails, if you run it only for the 4 rectangle walls (without the slab):
I attached the Revit 2023 file without the analytical model.
I would be thankful if someone could provide a setting for the analytical automation that works properly. I failed to find one.
Apart from that I wanted to mention my experience with that tool as negative feedback - hoping for further improvements.
Best Regards
Lukas
