Revit 2022 Version 22.0.10.28 falls over once an add in feature is installed
Member1RayG
Member1RayG
This is a very bizarre error. A Revit Education version installed last June worked fine. Used Hot fox to be compliant with Ver 22.0.10.28 - worked fine again. As soon as I installed links to either Naviate REX or Robot Structural Analysis Professional link the program boots up gets past the splash page ribbon fills in and properties and project browser about to fill in; then wham! Program drops out crashes with no error message no clue what is bothering it! Uninstall using WIN 10 programs and features usually brings back Revit 2022 from the dead. For some-one teaching the importance of interoperability and collaboration this is an unmitigated disaster.
The WIN 10 desktop has 32GB Ram and is a Xeon HPZ440 and has all the latest windows updates installed.
Ray Georgiou
Member1 rayg
RDAOU
@Member1RayG
Why don't you download/install 2022.1, what you have is 2022.01...maybe that issue has been addressed
https://knowledge.autodesk.com/support/revit/downloads/caas/downloads/content/autodesk-revit-2022-pr...
Member1RayG
Does that mean that I have to unistall 22.010.28 first or install over the top?
RDAOU
@Member1RayG
No just install the newer build on top
Member1RayG
Hi RDAOU,
Thank you for the solution. Your advice worked fine. Version 22.1 added the link to Robot Structural Analysis automatically into the Analyze tab once it detected that it was installed.
Rayg
