Revit 2022 - IFC Export - Columns does not appear
robert.jungergard
Message 1 of 1
robert.jungergard
We installed Revit 2022.1.1 now and when we use default IFC options my beams appears but not my columns.
There are no steel connections or anything like that, it is just beams and columns.
I have IfcColumns, IfcColumn, IfcColumnType, IfcBuildingElementProxy in my IFC options.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-EE6C0CF8-7671-4DCC-B0C7-EEA7513C90A9
I have tried with and without "Include Steel elements"
I have tried different coordinate locations.
I have tried with IFC2x3 and IFC4 but no columns.
I have added walls, slabs, floors and they appear but no columns.
This is a bit weird since we have not had this problem before in previous versions.
Do you have any other suggestions?
EDIT:
We have solved the problem.
We uninstalled the"Revit IFC Export 22.2.1.0" and went back to Revits default IFC export. That worked.
We also tried installing Revit IFC Export 22.4.0.0 from Github and it worked as well.
https://github.com/Autodesk/revit-ifc/releases
Replies (0)
