Revit 2021 Sheet order
William.Diduch
William.Diduch
Hello im fairly new to Revit, but im working on the structural side and according to the architectures, there are certain sheets not in order. So I have checked the properties of the two sheets that are not in order and the only thing that is different between them to the others is the independent data- sheet order has 0.000 while the others are blank. I was wondering if it is because of this is what is messing with the order. On our side everything is where it is suppose to be.
thank you.
 Image20220909113143.pngThis is according to arch.This is according to arch.This is the normal sheets.This is the normal sheets.
timlove
Just from a quick look and guessing, It looks like you did not sort the table by the sheet number.  In schedules that do not have a sort, revit defaults to the objects ID, which is typically the same order as when something was created.
