HI guys!
I'm having a little problem using synchronize function from Revit 2018 to Advance Steel 2018. I installed the add-on, and when i export the model from Revit, to Advance Steel, everything goes fine. All the elements are there. The problem comes when i add columns with foundations in revit and try to synchronize the models. The columns and every other element will sync, except for the foundations...
First i thought it was a problem with concrete elements... but then i put some concrete walls, and they were syncing ... I have a problem only with foundations..
Thank you very much!
Hi Daniel,
At the moment, Advance Steel doesn't support footing synchronization; this elements can only be imported. This behavior is present also in Advance Steel 2015, 2016 and 2017.
We have this issue in our backlog as a feature request.
Footing modifications can only be synchronized on the Revit side, using the Advance Steel Extension for Revit Synchronization dialog.
