Revit 2018 Extension for Reinforcement Generation of Slabs
The Revit 2018 Extension does include Options such as Slab Openings and Slab Corners but not simple Slab Option.
Can someone Help me out here as to how find this option in Revit.
 Thank You
awes
Use OOTB Structural Area Reinforcement, explode it and adjust.
Sir may I know what is this OOTB function
And how to use explode option
Do you mean to say to filter out the other elements while leaving the Slabs only
Thank you
awes
Check this :
https://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-13E5A71A-551A-4CF7-845A-2BDD5611A8E8. I'm using 2019 thtas why. There is also a help page for RVT 2018
a) Model a slab/ floor
b) Under Structure select "Area = Structural Area Reinforcement". Use default settings.
c) By exploding a mean "Remove Area System".
d) After "Remove Area System" you can change all properties for rebars, cover, spacing, layers etc
