Revit 2018.3
Revit 2018.3
MBCT
Message 1 of 11
Revit 2018.3
MBCT
The desktop app is not showing update 2018.3, is there anywhere to download and install?
MBCt
Replies (10)
Message 2 of 11
teodorb
Hi @MBCT,
Go to manage.autodesk.com and login with your credentials.
Go to All Products and Services, scroll down until you find Revit and press the 2018 version Downloads. A window will appear where you should press the Updates @& Add-ons tab. There you should see Revit 2018.3
Kind regards,
Bogdan Teodorescu
Product Owner
Message 3 of 11
I just spent a few days updating software on my works computers. Not a single one showed that AutoCad or Revit had updates. Only my personal computer ever shows me updates that are needed via this stupid desktop ap. I even logged into other machines, and still nothing popped up for the 2018.1.2 update for AutoCAD 2018, nor the Revit 2018 latest updates. I manually have been running those from the network. And now after doing all that, these is this update.
Please get your **** together Autodesk. Please get an desktop ap that actually works correctly. It is ridiculous that I have to login to the website to find updates, download them and go back and install them now.
Message 4 of 11
I have reinstalled Revit 2018 because of crashes.  Would this version be up to date?  Or do I need to download the hotfix as part of 2018.3 update?
Message 5 of 11
aRcHiTeCt.JM
.... you can download it and install it from here
.... Autodesk Revit 2018.3 Update
https://up.autodesk.com/2018/RVT/9CA05B9A-1809-0510-A1B4-98696E090436/Autodesk_Revit_2018_3.exe
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 6 of 11
There is a slightly newer update (hotfix).
See here for more information about the different updates:
http://revit.downloads.autodesk.com/download/2018_3_RVT/Docs/RelNotes/Autodesk_Revit_2018_3_1_Releas...
Message 7 of 11
aRcHiTeCt.JM
.... I got you
...  Autodesk Revit 2018.3.1 Update
https://up.autodesk.com/2018/RVT/9CA05B9A-1810-0510-A1B4-98696E090436/Revit_2018_3_1.exe
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 8 of 11
skhatri
Thanks for the link but the install fails.
where can i get revit 2018.3.3 update?
Message 9 of 11
There is no 2018.3.3 yet. There is a 2018.3.2 though that replaces 2018.3.1
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/downloads/content/autodes...
Message 10 of 11
skhatri
there is one which apparently came out a few weeks ago.
it says some security hot fix for Revit 2018.3.3
Message 11 of 11
Turns out you have to update to the newest AutoDesk Desktop App (released today 05/31/2019). Then you can upgrade to 2018.3.3  🙂
Here is where you can get the latest AutoDesk Desktop App:
https://www.autodesk.com/desktop-app
