Revit 2017 Steel Connection Won't Load to Properties Panel
Message 1 of 11
Hello guys,
Please help me, I wonder why the steel connection won't appear to the properties panel. This is the image. https://postimg.org/image/60afs1ag5/
However, when I tried to go to connection settings, it appears but won't load or show in the properties panel. Here's another image of this. https://postimg.org/image/orcd2kfet/
Please help me how to load this in the properties in order to be use.
Thanks for the help guys.
Replies (10)
Message 2 of 11
dzanta
this occurs sometimes....two possible reasons:
- wrong connection type being used in the design situation.  (i.e. using a column/beam connection for a column/footing connection)
- steel database file corrupted
try selecting the two members first then choosing the connection type to make
try reinstalling revit steel connections thru Autodesk Desktop App.  Remove via Control Panel first.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 11
Hello Dzan,
Thank you for the reply!
I have tried reinstalling many times the steel connection add-on but still the problem happens, also sometimes I get another problem, it crashes.Here's the sample image. https://postimg.org/image/a6mlmottx/
I have tried  uninstalling and reinstalling revit quite few times already. Also, have tried uninstalling and reinstalling steel connection add-on but unfortunately the problem occur...:(
Message 4 of 11
Message 5 of 11
Hello Toan, I have tried this already but error will prompt up like this when I click connection setting. https://postimg.org/image/8vjfrwig5/
I wonder if the system I have is the problem..:(
Message 6 of 11
dzanta
What are the specs on your computer?
OS
Graphics Card
Processor
HD
Have you tried a Clean Uninstall?...not just a regular uninstall.
Have you tried deleting your %temp% and Windows/Temp folder content prior to installation?
Message 7 of 11
Hello Dzan,
Here's the specs of my computer. https://postimg.org/image/hlzcvbv1h/
I have done once deleting %temp% folders but I don't if it is enough. In my experience yesterday, I have once seen the steel connections appear in the properties panel in a new project of revit. But when I tried to try it again to my project then it crashes. Today, when I try to load steel connections in a new project, it now crashes.
I will try to use a registry cleaning software like uniblue if this will solve the problem. Is this okay?
Message 8 of 11
Can you just embed the image in the post or attach it?  The site hosting your image keeps flashing advertising that is not suitable for most working environment, unless, of course you work in a certain industry.
Message 9 of 11
Hello Toan,
Sorry, I don't intend that but if that's the case. I'll try to find another way to upload image.
Message 10 of 11
See below:
Message 11 of 11
Thank you very much for all the reply and answers to my questions!
I have solved the issue, all I did is download a registry cleaner software, uninstall all my revit software and install them again after I clean my drive C. 🙂
