Revit 2017 Shaded with Edges Visual Style Issue
db
db
Hi... I have just updated from Revit2016 to 2017 and am having a problem with the graphics.  In the visual style "Shaded with Edges", the edges disappear when I pan or zoom.  Has anyone else noticed this problem ?
It seems from online searches that people using Inventor have had this issue but don't know how to solve it in Revit.
db
For anyone else having same problem, this solved it.....
Add this line to the Revit.ini file under the [Graphics] section.
OptimizedViewNavigation=0
Make sure you change the correct Revit.ini file....
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/Revit-Customize/files...
Found this solution from....
http://www.revitforum.org/architecture-general-revit-questions/29563-optimized-view-navigation-bdsp-...
Hi. I need some help with this please. How and where do one insert the solution?
db
It needs to be entered in the Revit.ini file which should be located at....
"C:\Users\<username>\AppData\Roaming\Autodesk\Revit\<product name and release> "
unless you have not already tried to start Revit, in which case the .ini file should be located at...
"C:\ProgramData\Autodesk\<product and release>\UserDataCache"
and then save the file
