Mike,
It is not isolated to one view. It appears in all views that associate with it in it's relative space (i.e. depth and horiz position).
If I create a new section view, it appears there as well.
I use section boxes, and the object falls within the limits. It appears to be a foot or 2 long, thats it.
I don't use scope boxes, so not sure how to check that.
The file is 16Megs. And I have a bunch of links to it.
So, instead of bogging down the forums with a huge file (not sure if that is a problem or not???) I did a purge
of all model objects, links, families and whatever was not being used to get it down in size. It is still there, amazingly.
This may also help you narrow down the number of problems to check. If it doesn't help, let me know if you want
me to send you the full size copy and any of its links and extra families.
Attached is the purged copy and 2 views for which it appears.
Thanks for the effort,
Jerry
