Retaining wall Opening
jazzsharma200
jazzsharma200
Can we make openings in the Retaining wall.
I have seen some videos pretty sure it can be done with structural walls.
can't find any solution in the Retaining wall.
ArmanMargaryan
In Revit 2022, this problem seems to be solved.
https://www.youtube.com/watch?v=I3huCkG4UNo
https://blogs.autodesk.com/revit/2021/05/11/whats-new-for-architects-in-revit-2022-modeling-document...
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
hmunsell
if you enable the Architectural menu you should be able to place a Door or Window opening in the wall.  Retaining walls are typically placed in a Negative offset from the Level. just make sure your Base constraint and offset for the opening are set appropriately. You should also be able to place a elevation and edit profile of the wall.
1=door opening, 2=Window opening, 3=edit profile.
done in Revit 2020
Howard Munsell
utech.udara
Once you created the wall, use edit profile and created additional boundaries as shown in figure. This also will create openings in a retaining wall. Hope this helps you!
