Report BUG - Custom Rebar Hook Length error
Tengbimkub
Tengbimkub
The first problem I encountered is that the units are displayed in millimeters, but if I want to get the number 500, I have to enter 0.5. I have encountered this problem since Revit version 2019 and it is still there. Worse, when I enter 0.5, the program enters the value 500000.0, which is not the number I want and I cannot edit it. Please fix this bug.
RPTHOMAS108
Units are whatever you set for reinforcement length project units.
The 0.5 = 500 comment I don't understand? It probably reverts to max. since 0.5mm is practically 0mm and so pointless (in 2024 version you get an error if you try that). In below hook length is number 4.
However I can't say I'm an expert at this Revit feature since in the UK we don't bother with added end hooks, they are specific shape codes instead i.e. you wouldn't say (00) with an end hook because that would be a (13).
