reinforcement bars in curved wall
kamaluddin.shaikh9
kamaluddin.shaikh9
i want to generate rebars in curved wall, bt use of only revit command, it is possible or not, if it is yes then how, if it is not then why,
A_MAQ
Hi ,
you can not make it directly as straight wall,
but it's achieved by revit commands by using adaptive component
you can have a look at this PDF it will shows you how to do that
Autodesk Expert Elite
MostafaElashmawy
curved wall can be treated as a column.
for the vertical bars you have to add one by one.
for horizontal bars draw a horizontal section and use sketch rebars tool.
Mostafa Elashmawy
